Results 1 to 10 of 18
Thread: Problem starting my VR6
    Nov 2008
    Canberra
    Hello,
    Today when trying to start my car, I was surprised that the engine did not crank over when I turned the key. After trying many times, I finally remembered the person whom I bought the car from saying something about pushing the key into the ignition.
    The ignition seems spring loaded, is this a design of the car?
    The first few times I started the car up, I did not make a conscious effort to push the key into the ignition.
    Should I be talking to the mechanic about this?
    Dec 2007
    Ermington, Sydney
    ....Did it actually work when you pressed in? lol
    AFAIK none of the VR6 ignitions need to be pushed in to start the car.
    Jul 2007
    Canberra
    As long as it works when you push it in I guess it's not an issue but mine certainly doesn't require it.
    2008 VRS Wagon. Yellow, very yellow!
    Forever blowing bubbles.
    Camden, Sydney
    It could be the chip in the key not making contact with the magnetic reader. Turn the key over and try the other way next time it does it, or try the spare key.
    Or it can be the ignition switch on the back of the barell worn, try lifting the key as you turn it and see if that helps.
    Jan 2007
    Quote Originally Posted by Mrk_Mickey View Post
    Oh thats good to hear, I thought my ignition barrel was broken! The GL one needs to be pushed in order to turn.
    Jul 2007
    Canberra
    Must be a later model thing?
    Camden, Sydney
    Quote Originally Posted by Pullstarter View Post
    No its a knackered ignition barrel thing
    Jul 2007
    Canberra
    ah ok, not a serious issue though i guess? Well unless it ceases starting LOL.
    Jan 2007
    Quote Originally Posted by Golf Loon View Post
    So whats the barrel in a VR6 MEANT to do?
    Nov 2008
    Canberra
    I tried everything as suggested. the car started when I pushed in the key.
    The manufacture date for the car is 4/98.
    Is it costly to replace the ignition barrel? I hate to have to wriggle the key each time I start the car!
    ps. I dont have a spare key. car only came with one key! what am i looking at in terms of cost for a coded key?
