Power window going click will be the motor mate, and the door lock paddle that operates the microswitch in the door will be broken and held in the lock or unlock position. Remove the outer door handle and you will see what i mean. the paddle is attached to the handle and is very very common to breakage. New paddle will fix if this is the case . You will see what the paddle goes into on the lock module. In the rest position the slot will be at the 12 oclock 6 oclock postion anything other than that will be commanding the module to lock or unlock, this is so because u are operating a micro switch. MAte to be honest you can swap the door handles left to right all that it will change is you cant lock or unlock from the passengers side - EASY fix
Jmac
ps just noticed you are talking about the left then check the same on that door if not module may be misbehaving
Alba European
