Results 11 to 20 of 37
Thread: Pmk's green goblin vr6
    Aug 2008
    Rowville, VIC
    i bought a spare one from this dude
    Lame DE Pare Choc Spoiler Noir VW Golf 3 Type VR6 Neuf | eBay
    its the cheapest ive seen anywhere and looks the same
    Apr 2011
    Sydney, Campbelltown
    Quote Originally Posted by timiteo View Post
    Looking good! I do like the N/A lip, makes you look lower than you are :p
    Who did you order it from?
    Sent from my Nexus 4 using Tapatalk 2
    Quote Originally Posted by filthyimmigrant View Post
    loving that lip.
    yeah as above Timiteo said, where'd you get it from bud?
    Quote Originally Posted by decksla View Post
    As above !
    Build and learn, not buy and earn.
    Apr 2011
    Just done a bit of things here and there to make driving this a little bit more fun. Car was missing speakers all round so fitted the speakers in the car that i had spare and also the headunit finally got in after awhile and cleaned up the wires in the dash.
    Car's water reservoir wasn't working and pumping out water so i found out it looked like this;
    So i hopped down to my mates place where he was wrecking the same car and replaced it!
    Also got to do a fender roll at his as he had one spare ! lucky for me !
    During a few weeks ago i got a nice little package and got myself one of these. Chrome Intake Cold Air Intake.
    Custom made for the VR's and finally installed it last weekend. Took me a long while with some research relocating the charcoal canister to fit the CAI and found a litte bit of metal piping to make it match up.
    Also picked up a set of replacement hubs and axles. My current ones LHS Abs ring is bent and removing it may cause trouble with the currrent axles so the replacements are here in case. Only thing is i have no idea how to do this, and also don't have much time only a bit on weekends.. So this should be interesting..
    Also when i picked it up it was late i noticed that the rubber mounting on one was ripped.. Will this affect the use of it ? as the bearings and all will be exposed? would be good to know !
    Also this.. Till next update. Should be fun !
    Aug 2006
    Melbourne VIC
    Replace the CV boot its a MUST. They are like $20.
    Apr 2011
    Re: Pmk's green goblin vr6
    Good stuff mate!
    The 'rubber' part is a Constant Velocity or CV boot. It protects those 'metal parts' which is called the CV joint from dirt and rubbish (plus stops the joint spitting it's grease all over the place). Just grab a CV boot kit for like $30 and chuck it on (may also be a good idea to put some new grease in). Then you'll be laughing.
    Also, if it was like that for a while when on the donor car then the joint itself may be stuffed too. You can tell if the joint is stuffed normally when you turn full lock at low speed and it keeps going clickity clack haha :p
    Edit: It appears I've been beaten to it while writing. Many for your keyboard prowess.
    as per above.
    But it looks like it might have been dry a while... id be worried about the CV failing
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Oct 2012
    Would highly recommend doing all of them while theyre out. They look fairly old and they're a pain in the arse to do if they're installed. Take it apart and repack with grease and you will be saving yourself a heap of trouble in the future.
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
    Apr 2011
    Quote Originally Posted by Water Boy View Post
    Good stuff mate!
    I forgot they were called cv boots haha derp. Would it matter which kinds ? I'm looking at easiest accessible for now as uk ebay would be the best friend.
    as per above.
    Quote Originally Posted by mb1907953 View Post
    Yeah definitely. Will be taking a crack at this using this diy on vortex;
    VWVortex.com - DIY - Blown CV Boot Replacement and inspection
    VWVortex.com - Wheel Bearing and Hub Replacement DIY
    But at the end of this all i need is the abs ring that was "supposedly" the problem as been checked from a blue slip. Should i just take the hub only and replace it or the entire hub with the axle ? At this stage looking at the DIY, i think i might take it to a shop and watch and learn there as i don't have the tools to do this thing as of yet. The CV boot easily but it seems their is more to the Hub/axle. Anyone care to teach ?
    Apr 2011
    Doesn't matter too much which boot. If you just want to pass the blue slip then I'd say just swap the hubs.
    The hub should come free of the drive shaft if you take the split pin out and undo the big nut in the middle. An air impact gun would help as you'll have a hard time doing the one that's off the car. The one on the car you could just use a breaker bar or socket with a pipe on the end if you need more torque.
    Then swap the hubs and see the blue man
    Jun 2013
    Leichhardt, NSW
    Nice, i remember looking at this car when I was looking for a VR6 but didnt end up buying it, got one in the gong instead. nice to see the updates.
