Results 1 to 10 of 14
Thread: please help!
    Mar 2010
    Carlingford and camden, NSW
    please help!
    So, I got home and parked my car on the driveway and realised i left my lights on, but when i went to turn them off the switch was already off and turns out just my right hand park and tail lights were still on..
    anyone had this happen before? I disconnected them so i didnt drain the battery.
    any help much appreciated.
    Sep 2009
    flick your indicator back to the middle
    Feb 2010
    i havent had that problem with my mk3 but i do recall that sort of thing happening to my toyota corona. is your brake pedal slighty pressed in? could be getting stuck?
    Without Your Seatbelt, You Know Your Gonna' Die!
    Project: mk1 cabriolet 20vt
    Mar 2010
    Quote Originally Posted by DUB84 View Post
    I dont think so i checked and it seems to be normal, though being the idiot i am when i disconnected them the wires touched a bulb and it sparked now the right hand park and tail light dont work at all and the right hand side repeater flashes really quickly so i assume i blew a fuse?
    Quote Originally Posted by sortofbigbj View Post
    Do you mean the indicator stick? because that was in the middle when they were on and i flicked it to left and right and back to middle left hand works normal right hand flashes quickly and when i put it back in the middle its the same as it was
    Sep 2009
    Alright. Pretty sure when you turn the car off then have the indicator on it leaves the parking lights on on that side, so was just an idea
    Oct 2005
    SE Queensland Hinterland
    sortofbigbj is correct the indicators leave the parking lights on on that sise. Did you check with the ignition OFF/ otherwise you're not really testing the theory!
    Mk3 Golf Tdi about to sell
    Mk 1 Golf GLD somewhere in a paddock!
    Mk1 Golf Cabriolet
    MK2 Golf Turbo diesel engine and 5 sp gearbox
    Mar 2010
    ok thanks well ill check again but i think i blew a fuse disconnecting the lights so i cant until that is replaced anyone know which fuse it is and where to get one?
    Check on the fuse box panel, it tells you what fuse if for what. Most likely be the one for lights!
    Dec 2006
    Kilsyth, VIC
    As has been said, if you leave an indicator on and turn the car off the parking lights on that side of the car stay on. It's a safety feature on many Euro cars.
    As for the fast flashing, there is a good chance it's just the busted bulb, basically a dead bulb means fasat flashing to tell you there is a dead bulb
    Mar 2010
    ok thanks guys im a bit of a noob my VR6 is my first real car haha
    does anyone know where i can get the fuse from? supercheap?
