Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 76
Thread: Please Explain..
  1. #21
    Aug 2006
    Skye, Victoria
    I'll take a photo of where mine is when i get a chance, cant get much cooler than where it is.
  2. #22
    Jul 2007
    Constitution Hill
    Quote Originally Posted by Soundofav6 View Post
    Can some one explain to me why my k&n filter has a weird shape, does it matter? What did I do wrong this time?
    doesn't your car ping?
    better to get a heat shield me reckons, it's just the right thing to do. it is a fact that your car runs better when its cooler. then again, that pod looks quite large, you might have to do some customisation.
    nothing wrong with the shape.
  3. #23
    gpk_gti Guest
    Quote Originally Posted by cOS View Post
    why would it ping?? nothing to do with the fuel.
  4. #24
    I don't mind putting a head shield there, but the thing is I see logic when the car is running and cold air through the car anyways. But have also seen and felt a a VR6 with hand hand placed in the heat shield side and out side of heat shield, there is a difference for sure. But when the car is running, air flows through anyways.
    Well.. to put a shield will give me another little project to do, probably one day I will do it not becasue I was persuded but out of bordom, honestly I am happy with the money spend and the power gain already.. at least with out a shield it does not/ will not have an adverse effect right.
  5. #25
    By the way what is a ping anyways?
  6. #26
    Nov 2006
    Central Coast, NSW
    if you put cheap ass fuel in a golf, it doesn't like it - and it tells you... if you try to pus it at all you will hear a pinging noise coming from the engine. I use 95 octane minimum but I try to put 98 in when I can. The difference is astounding.
    Is the power gain really that much? Is a drilled airbox decent in comparison to a pod filter for the money spent?
  7. #27
    Jun 2007
    Hi Louis,
    Pinging is a sort of rattling sound you hear usually at high load and lower in the rev range when certain conditions exist. There are a number of causes, most often fuel of a lower octane rating than required but it can also be caused by other factors such as incorrect ignition timing or a severe build up of carbon in the combustion chamber etc.
    What is actually happening is premature combustion i.e. the fuel burns before the piston gets to the top of the combustion stroke. It is a condition that should be avoided at all costs as it can be very destructive to your engine.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
  8. #28
    gpk_gti Guest
    guys!!!!!
    cOS asked if the car pings since the airfilter was fitted....
    I had a pod on my vr6 for over 5 yrs and it never pinged.why would he ask this question? its totally unrelated.
  9. #29
    Sep 2006
    Australia?
    Something other is the problem obviously!
  10. #30
    Jun 2007
    Quote Originally Posted by gpk_gti View Post
    guys!!!!!
    Must admit the question confused me also as there is no relationship between the two issues.
    George
