Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: performance help?
    Jun 2012
    performance help?
    hey guys im almost posative this has been asked heaps of times before but couldnt find the thread. i have a 94 vr6 golf and an wondering the best mods i can get, value for money ect. not just engine but breaks, suspension, sway bars ect. please get back to me asap as i have a week off next week and wanna get started. let me know. thanks
    Jun 2011
    If you have ever looked under the mk3, you'll see how damn skinny the sway bars. I haven't got aftermarket ones, but I reckon they would make a massive improvement.
    Coilovers for some lows/handling.
    Airbox mod, 1.8t iat sensor, suitcase delete.
    Dec 2008
    sydney
    How deep are your pockets?
    MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
    MK6 GTI: MY13, DSG , very stock
    Ducati 749
    Apr 2006
    VW Race HQ - Sydney
    Start with maintenance first . If your timing chains havent been done do those first , while your at it fit some 268 cams . Then there is the clutch as well , and an lsd .
    Bug_racer supports the rebellion of the euro revolution
    Jun 2012
    hey pockets are reasonably deep, im after brands to guys cos i dont no where to look for this stuff. suitcase??
    not keen to turbo it either before anyone starts down that path. have given the engine a major overhaul already. what sort of cams
    Jun 2011
    Drc's are cheap 268's but apparently drop off at 5000rpm, schricks are more expensive but pull a bit longer.
    268's they recommend hd springs. 262's are cheap as and are Dyno proven to be nearly as power making capable as 268's without needing springs.
    The suitcase is a restrictive heavy mid muffler on the vr.
    If your planning biggish. I'd recommend a 10lb steel flywheel from autotech. It has made the engine much more perkier and a bit quicker.
    Aug 2006
    Melbourne VIC
    - Service
    - Polish
    - Clean up interior
    - Stereo
    - EBC pad brake pads, godo rotors and full system bleed.
    - Cat back 2.5" exhuast, check out brands such as TT, Miltek, Jetex.
    - Modded intake (swisse cheese and drop in panel filter)
    - Now i beleive the best mod for any VR6 wanting to go faster is reduce the final drive. VR6's have a very tall ratio box so designed for the autobahn etc. You can pull like 160km/h in 3rd gear. So getting it to accelerate faster with a final drive reduction would be the way to go.
    Jun 2012
    thanks heaps this sort of stuff is perfect, any idea ho much im looking at and is there a website for them?
    Jun 2012
    Quote Originally Posted by Water Boy View Post
    - Service
    - Polish
    - Clean up interior
    - Stereo
    sounds good how would i go about that?
    Jun 2011
    Quote Originally Posted by MadHouse View Post
    Schricks are something like $700
    DRC's are about $500
    The 262's on autotechs website are ~$300 from memory. If your going to look at getting these. I'll get some with you to reduce cost. I use preeny59 (chris at tprengineering) for autotech gear he is great.
    As for exhaust, they are pretty restrictive. But I've heard pretty droney results from bolt on kits, plus by the time you get them here a local shop coud fab and equally good one up for less.
    A ratio adjustment would be awesome. Sucks only being able to floor it for one gear and be doing the highest legal speed limit.
