get some prepsol on a rag that will get it off if that doesnt work try and buff it out but make sure the area u are buffing doesnt get to hot
dont u hate when u find new scratch or anything like it on ur beloved vw
due to the latest water restrictions i havent been washing my car as often, when i washed it the other day i found some s*** stuck on my paint, just behind the front wheel, place where stuff coming of the wheel hits the paint
when i washed it off, this is what i was left with
i dont know what it was, but it changed the color where it was stuck
thats not all it just didnt fit in a pic frame![]()
Jeez! I'd love to be able to help but all I could say is trusty ol' cut n polish? seems to have worked for me over the years. . .
If all else fails I guess you could give it a paint touch-up. May be a more expensive option.
Found some info on factory paint codes. Don't know if the paint used in American Golfs were the same as the European/Aussie ones.
That's why I put mudflaps on my Mk III, as un-cool as it may look.
See my thread a little further down.
Maris
thanx for fast response,
if i buff it out, do i do it by hand or the electric powered for more speed
and what sort of attachment/wax should i use
havent been working on paint before![]()
by hand first then with buffer but dont keep in one place to long
is it stuck on your paint?
I would try to get it off with a clay bar
you can get a meguiars clay bar from supercheap, wolfies etc
it comes in a pack with quick detailing spray which is like a lube.
spray very liberally over the area, get the clay bar (which is like play doh) and roll it into a ball, this will heat up the bar and make it more malleable, then rub it over the spots in a circular motion.
this will strip previous wax off your paint. but is the best method for giving your paint a deep clean and can also be used for tar spots grime etc
also if your clay bar is picking up this grime you sould fold it to expose a clean area each time you use it. But the main thing is you need plenty of lube spray
I'd reccomend claying the entire car every 6 months, then following that a good polish and then a couple of coats of wax and your paint will be silky smooth
cut and polish works a treat with stuff like that mateALWAYS do it by hand, keep away from the buffer until the final once over!
from autopia car care
this explains it better than what i can
http://autopia-carcare.com/inf-clay.html
