Results 1 to 10 of 11
Thread: paint...
    Jul 2005
    That's why I put mudflaps on my Mk III, as un-cool as it may look.
    See my thread a little further down.
    Maris
    Jun 2006
    thanx for fast response,
    if i buff it out, do i do it by hand or the electric powered for more speed
    and what sort of attachment/wax should i use
    havent been working on paint before
    Oct 2006
    sydney
    by hand first then with buffer but dont keep in one place to long
    midget Guest
    is it stuck on your paint?
    I would try to get it off with a clay bar
    you can get a meguiars clay bar from supercheap, wolfies etc
    it comes in a pack with quick detailing spray which is like a lube.
    spray very liberally over the area, get the clay bar (which is like play doh) and roll it into a ball, this will heat up the bar and make it more malleable, then rub it over the spots in a circular motion.
    this will strip previous wax off your paint. but is the best method for giving your paint a deep clean and can also be used for tar spots grime etc
    also if your clay bar is picking up this grime you sould fold it to expose a clean area each time you use it. But the main thing is you need plenty of lube spray
    I'd reccomend claying the entire car every 6 months, then following that a good polish and then a couple of coats of wax and your paint will be silky smooth
    cut and polish works a treat with stuff like that mate ALWAYS do it by hand, keep away from the buffer until the final once over!
    midget Guest
    from autopia car care
    this explains it better than what i can
    http://autopia-carcare.com/inf-clay.html
    Jun 2006
    thanks for all ya tips fellas, was helpfull
    i got some cut n polish paste and it worked so well on thos spots that i decidet to do the rest of the car and it worked really good, used good long polish afterwoods
    the car is improved amazingly well, im so surprised, cant believe i never used it before
    anyway, cheers and thanks again
Similar Threads
  1. aus delivered paint codes
    By joshyd-mk2gti in forum Mk2 Golf & Jetta
    Last Post: 07-10-2006, 06:18 PM
  2. Crome or paint?
    By GoLfMan in forum Mk1 Golf
    Last Post: 15-06-2006, 03:02 PM
  3. how to get a showroom shine when u paint?
    By GoLfMan in forum Bodywork/Trim & Detailing
    Last Post: 10-11-2005, 05:58 AM
  4. Paint Codes
    Last Post: 26-09-2005, 10:33 PM
