Results 1 to 10 of 11
Thread: paint...
    Jun 2006
    paint...
    dont u hate when u find new scratch or anything like it on ur beloved vw
    due to the latest water restrictions i havent been washing my car as often, when i washed it the other day i found some s*** stuck on my paint, just behind the front wheel, place where stuff coming of the wheel hits the paint
    when i washed it off, this is what i was left with
    i dont know what it was, but it changed the color where it was stuck
    thats not all it just didnt fit in a pic frame
    Oct 2006
    sydney
    get some prepsol on a rag that will get it off if that doesnt work try and buff it out but make sure the area u are buffing doesnt get to hot
    Sep 2006
    Parkinson / Brisbane
    Red face
    Jeez! I'd love to be able to help but all I could say is trusty ol' cut n polish? seems to have worked for me over the years . . .
    Sep 2006
    West Sydney
    If all else fails I guess you could give it a paint touch-up. May be a more expensive option.
    Found some info on factory paint codes. Don't know if the paint used in American Golfs were the same as the European/Aussie ones.
    Jul 2005
    That's why I put mudflaps on my Mk III, as un-cool as it may look.
    See my thread a little further down.
    Maris
    Jun 2006
    thanx for fast response,
    if i buff it out, do i do it by hand or the electric powered for more speed
    and what sort of attachment/wax should i use
    havent been working on paint before
    Oct 2006
    sydney
    by hand first then with buffer but dont keep in one place to long
    midget Guest
    is it stuck on your paint?
    I would try to get it off with a clay bar
    you can get a meguiars clay bar from supercheap, wolfies etc
    it comes in a pack with quick detailing spray which is like a lube.
    spray very liberally over the area, get the clay bar (which is like play doh) and roll it into a ball, this will heat up the bar and make it more malleable, then rub it over the spots in a circular motion.
    this will strip previous wax off your paint. but is the best method for giving your paint a deep clean and can also be used for tar spots grime etc
    also if your clay bar is picking up this grime you sould fold it to expose a clean area each time you use it. But the main thing is you need plenty of lube spray
    I'd reccomend claying the entire car every 6 months, then following that a good polish and then a couple of coats of wax and your paint will be silky smooth
    cut and polish works a treat with stuff like that mate ALWAYS do it by hand, keep away from the buffer until the final once over!
    midget Guest
    from autopia car care
    this explains it better than what i can
    http://autopia-carcare.com/inf-clay.html
Similar Threads
  1. aus delivered paint codes
    By joshyd-mk2gti in forum Mk2 Golf & Jetta
    Last Post: 07-10-2006, 06:18 PM
  2. Crome or paint?
    By GoLfMan in forum Mk1 Golf
    Last Post: 15-06-2006, 03:02 PM
  3. how to get a showroom shine when u paint?
    By GoLfMan in forum Bodywork/Trim & Detailing
    Last Post: 10-11-2005, 05:58 AM
  4. Paint Codes
    Last Post: 26-09-2005, 10:33 PM
