Well that sheet has Bob Jane T-Marts written on it. So perhaps ask your local Bob Jane??
where in sydney can i get an wheel allignment done that provides that sheet after?
every time i'v got one done they just give you the recipt of the charges and thats it.
I went to Jax to get mine done. I was given a fairly comprehensive "result" sheet that was similar to BlackVr6ix's. However, I'm sure they'll give you a results sheet if you ask for one.
What was the deal with that abundance of toe-out on the right-hand front wheel?? I had a similar problem with massive toe-out but that was only cos I was replacing my suspension. You could actually physically see both wheels point outwardsMy bad for not marking the lower bolt mounts before taking them out.
heismans suspension on princess highway after hungry jacks they are great steve by the wear on your tyre i would get it done asap too vw sugest it gets done every serviceOriginally Posted by 1DUB2C
so did you actually search the factory settings up and told what the guys to adjust?
I would never recomend getting a wheel alignment at a tyre service. I have seen so many bad things and lies. Suspension specialists are the only way to go.Originally Posted by william
They had the factory setting in their lookup system. the toe was due to my mechanic not knowing VW's, throw him an alfa or a fiat and he can work with his eyes shut. I'm guessing he screwed up when re-assembling after replacing the lower control arm bushes.
Got mine done today. Fair bit of toe on the right front which has been corrected.
Steers, brakes and pulls away WAY better now![]()
Mmmmmm, Black VR6.....
Thanks
1DUB2C!
I got the cheap tyres it was great value![]()
I got my wheels alligned there as well
but they say they can't do the camber
I went back with the workshop manual
and said you can do it look!! and rhen they pulled
the whole we don't have the tool.
do all mk3s have the tool on the car some
where??
