VR6 Hard start
I have problem with starting my VR6. Need to turn key few times before start engine in the morning plus need to push acceleration pedal a little bit. During day time start after 2-3 times turning key. Look similar when you start engine with spare key without immobilizer - just start and cut-off few times before start normally.
All rest is 100% normal: power, driving, acceleration, fuel consumption....jus bad is start!
Can be: fuel pump, fuel filter, maf sensor, fuel pressure regulator, ignition coil, fuel line, vacuum line, coilpack, crank sensor, too many to listed...........
Any help or sugestions please.
THANKS
R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
