Results 1 to 10 of 23
Thread: opinions on this VR6 please
    Nov 2008
    Cheltenham, Victoria
    Back from the second look.. I left a (refundable) deposit on it pending service on Tuesday and possibly an RACV check.
    My findings:
    Log books are good, also had many receipts
    Thermostat housing repair mentioned in a receipt from a few years ago
    ABS light not working, but recent receipt says ABS ok, just bulb blown
    Brakes will be done this service (Edit: apparently don't need to be done)
    Clutch doesnt seem to slip; did the hill test as well as I could
    No obvious tappet or timing chain noises from cold (does timing chain ever need changing?); engine smooth
    Owner says it doesn't use oil; oil seemed clean
    Coolant seems ok (red coloured, doesn't appear to be from rust!)
    No obvious rust
    Tyres seem evenly worn
    Slight lumpiness at idle; no hint of stalling though; normal?
    Power windows working (forgot to check rears though)
    A/C; forgot to check this time, seemed ok last time
    Didn't notice any CV noises on tight turns
    Heater works; however... it was quite smelly. Reminded me of that hot, damp smell when I've had a radiator overheat. Quite unpleasant and wouldn't expect this as being 'normal' of a 1996 car. Owner didn't seem to think there was a problem (but he wasn't in the car this time). Also noticed with heater up full blast that the window started fogging... seems to indicate moisture that shouldn't be there, or is this common? This is my only real concern at this stage.
    Any and all comments appreciated. Cheers.
