keep the info coming guys, this thread is useful to everyone!
my contribution (info i've gathered on the web, sorry if it's repeated):
- uneven wear on tyres?
- graunchy syncromesh in 2nd gear/reverse?
- worn out shock absorbers?
- Is the air con delivering chilled air on start up?
- Any oil/fluid leaks?
- Any oil in coolant?
- Put the steering on full lock and accelerate to check CV's
- Make sure the ABS light turns on when you start the car, then turns off.
- Check to see if engine, chassis plates match.
- LOG BOOKS!!
- Has the heater core been replaced? Almost certainly will need it done.
- Check all electric windows work.
- Check condition of thermostat housing/ crack pipe
- Check for milky water under oil cap.
- Check for any rust.
- Has the timing belt been changed yet?
- New clutch?
