DON'T ATTEMPT TO DRIVE THE CAR! ... Lock it up and get it picked up.
Dave
SOMEONE PLEASE HELP!!! I have no idea what the hell caused this, but here's what happened:
My mate was sitting in the drivers seat (don't ask..) and was fiddling with the keys in the ignition. in 1st gear, not on, handbrake applied. for some STUPID reason he "accidently" turned the key and it jolted forward as it was in gear, then we heard a massive BANG. I thought it was a backfire or something, I had a panic attack popped up the boot didn't know what to look for etc etc..
After I looked underneath the car and found many small pieces of exploded plastic, I worried more, and eventually found my problem. THIS:
I took one look at it and swore. Loudly. "Something to do with my airbox blew up! What the F@#K?!?!"
I couldn't believe it! It blew up because the car jolted!
Stupidly, I turned the engine on...it was idling so badly..shuddering, couldn't keep steady, constantly almost dropping out. after just touching the accelerator pedal, it revved real high then dropped out completely.
Here's what remains..not a good sight
This is obviously a big problem. AND it needs to be taken to my mechanic for a bloody hose on wednesday, so I need it fixed before that. I guess what I need to ask you all here is....explain, help, something?!?!
Dave
I wouldn't dare!!
Surely someone on this forum will have a spare or something rather that can be fitted (..fixed..)? I hope and pray?
Well ... have you got a mate (or family member) you could ring to get a tow home? Or are you an AA member?
Dave
Hey.. Not such a big deal.
That plastic can is the noise damper for the idle control valve.
As part of installing a Schrick Manifold it is recommended that you remove and bypass this part. I have done this on my car when I installed my Schrick manifold and it's fine.
This is step 6 on the link below... As I said don't worry about it. You could get a replacement but you could also bypass it. Your choice...
6. "Mount the throttle body cable bracket to the intake. Detach the noise damper of the idle control valve (where present) and connect to the idle control valve directly to the air throttle body adapter/distributor. (OBD I Only)"
http://www.venommotorsports.com/libr...rickVGI268.asp
Hahahahahah..I like how it says IDLE CONTROL VALVE.
Sorry, newbie=me, where is it? It hasn't bloody blown up from the picture, has it? I've got different angles if you can't see it
I'll leave you in sc_rufctr's hands. I've got a Pogo and I was just trying to make sure you did no further damage.
Cheers,
Dave
Looking at this pic ... it definitely has blown up...
These pieces are the remains of your noise damper.
As I said you can by pass it but if you don't feel confident maybe getting it towed to your mechanic is the best option. Good luck...
sorry I meant has the idle control valve blown up..please don't say that's the same thing cause i assumed it was different
Your idle control valve is under the black plastic cover that holds you spark plug wires in place... You have to remove this to see it... It a fat aluminum tube shaped object...
