Results 1 to 5 of 5
Thread: oil on inspection plate
b0k1 oil on inspection plate 31-03-2012, 08:02 PM
paulie71 certain its the rear seal and... 31-03-2012, 09:22 PM
b0k1 yep, leaking oil from the... 31-03-2012, 09:28 PM
paulie71 bugger! you have remoed the... 01-04-2012, 01:35 PM
b0k1 yep gonna do the whole lot.... 01-04-2012, 07:08 PM
    Jul 2009
    Hey, my rear main seal is leaking and oil was found on the inspection plate. What are the chances that the oil soaked into the clutch and it has to be replaced? Clutch seems fine while driving, could I get away with just cleaning the oil off when replacing the rear main?
    thanks
    '94 3dr vr6
    Dec 2007
    Somewhere in Melbourne, Victoria
    certain its the rear seal and not a leak around the sump gasket? These can leak, especially if there are tell-tale signs of drivers bumping the sump.
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Jul 2009
    yep, leaking oil from the bottom of the bell housing
    '94 3dr vr6
    Dec 2007
    bugger! you have remoed the inspection plate by the sound of it.
    Depending on the quantity of oil seeping it might not have spoiled the clutch material.
    If it has you would sense it soon enough on the clutch.
    If you do need to change the rear seal you might as well do the clutch, unless you know the clutch is new or near new.
    while you're there you can do the rear seal housing gasket and remove all doubt of any leaks there for a few years
    Good luck.
    Jul 2009
    yep gonna do the whole lot. would you know the part number for the housing gasket? or a link/pic? can't seem to find it, or do you mean the lower timing chain cover?
    thanks
    '94 3dr vr6
