Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Oil cooler seal
    Mar 2014
    Bundoora, Victoria
    Exclamation Oil cooler seal
    It's a 59mm diameter, 5mm thick with two inside flaps. T4 uses same seal I believe.
    Where can I get one ASAP in Victoria?
    Thanks.
    Past - '95 VW Golf MK3 VR6
    Dec 2008
    Sydney/Canberra
    If you ordered one from VW tomorrow morning, you'd probably have it Tuesday morning.
    Otherwise, try your luck with Imparts and HSY.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2014
    Bundoora, Victoria
    A bit noob, but do I just call up the dealership? Can I go to the dealership and ask them?
    Where would be the closest one I can go to, to do this? (P/C is 3083).
    Thanks.
    Dec 2008
    Sydney/Canberra
    Go to your nearest VW dealer, and head straight to the parts department with your VIN, and ask them to order in what you need.
    '01 Beetle 2.0
    Mar 2014
    Bundoora, Victoria
    Thanks, I have the part number too.
    That would make things a lot easier yes?
    Dec 2008
    Sydney/Canberra
    Yes, it usually does.
    '01 Beetle 2.0
    Mar 2014
    Bundoora, Victoria
    I'm fairly sure it's part 038117070A that I need, but would rather ask someone with more knowledge on here before I go around asking for the wrong part...
    From my researching, the symptoms people described match mine so I think I am on the right track.
    Dec 2008
    Sydney/Canberra
    Oil cooler seal-2649b46023ffcdc68a594a61de39ef34-jpg
    I can't see what you're talking about anywhere in that pic.
    '01 Beetle 2.0
    Mar 2014
    Bundoora, Victoria
    (not my pic, from internet)
    From what I can see it is likely that this has failed, as the whole cylinder that houses the filter is covered in oil, and if that seal were to fail I would expect that to happen.
    Mar 2014
    Bundoora, Victoria
    This is what mine looks like.
    Dripping down the sides.
