Results 11 to 20 of 22
Thread: Oil cooler seal
    Dec 2008
    Sydney/Canberra
    Ah yes, found it.
    Shows two part numbers for that seal, which you'll only be able to confirm with VW using your VIN.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2014
    Bundoora, Victoria
    Alright, thanks for the advice. Will be heading around tomorrow.
    Past - '95 VW Golf MK3 VR6
    Jan 2011
    Mt. Waverley, Victoria
    There are 2 o-rings for the oil cooler, one on each side.
    038117070A is between the cooler and the filter adapter
    038117070 is between the cooler and the cover
    try call imparts
    '95 Golf VR6 Colour Concept
    Mar 2014
    Bundoora, Victoria
    Haven't installed the part yet but having some success in eliminating the problem.
    Can someone tell me what this block in the left of the photo is? The one with 3 plugs.
    Thanks!
    (pic found on internet)
    Dec 2008
    Sydney/Canberra
    That's what the oil filter screws onto.
    '01 Beetle 2.0
    Mar 2014
    Bundoora, Victoria
    I'm aware, sorry, what I meant was what are those three plugs for and could oil seep out of them?
    If the oil isn't coming from there then possibly the oil cooler on the right is leaking onto those plugs?
    I have given both a decent clean so that I can see next where the oil comes from.
    Mar 2014
    Bundoora, Victoria
    UPDATE:
    Found the source of the leak. It's coming from the black plug as pictured. Hopefully will be able to fix easily.
    Dec 2008
    Sydney/Canberra
    Yeah, that's the oil pressure sender.
    '01 Beetle 2.0
    Mar 2014
    Bundoora, Victoria
    Can the plugs be disconnected temporarily? I removed them to get better access but need to go drive get the correct socket in order to tighten it.
    Dec 2008
    Sydney/Canberra
    Can't hurt to leave them on, otherwise the dash will light up like a Christmas tree.
    '01 Beetle 2.0
