Turning the key only had the oil Christmas light come on.
It's just a PITA to work down there so rather put them back on after I've tightened the things because I will have to disconnect them again to tighten them.
Deep socket and small ratchet looks like the best way to do this with the limited space.
UPDATE: All I need is a new pressure sensor and I'm good to go. Easy.
Not so easy, I can't get enough torque to remove it.
Do I really need to remove the whole front end so that I can get to this thing?
At this point, getting some teflon tape and wrapping it around will be easier.
Past - '95 VW Golf MK3 VR6
