Results 1 to 8 of 8
Thread: oh geez (fuel leak content)
    Jan 2008
    After filling up at the servo today I had the misfortune to find that my car (VR6) was leaking a ****load of fuel from what seemed like the tank. I hadn't even turned the car on it just seemed to leak out somehow. It looked like a good litre or so came out. It eventually stopped so I figured there must be a problem somewhere between the fuel filler neck and the fuel tank. I unscrewed the fuel pump cover thing and everything in there is dry. My mechanic said something about the overflow hoses or something like that might have given up. It's definitely coming from the top of the tank somewhere, if anyone has any ideas what might have screwed up in there please let me know. It seems like the fuel tank will have to be dropped and I just hope its not some integral part of the fuel tank itself so I won't need a whole new fuel tank. Any help? Thanks in advance.
    Oct 2006
    Do u smell fuel inside the cabin? Could be that u just overfilled it and it came out the overflow hole which is at the top of the filler neck.
    Jan 2008
    I'm 99% sure thats not the case. No fuel came back out the fuel filler neck, the whole area around there inside the fuel filler door is clean. It was definitely coming from somewhere up the top of the fuel tank. I didn't fill the car any fuller than I do usually...
    Dec 2006
    Kilsyth, VIC
    Is it your "usual" servo? Different pumps, different angles of the ground etc can make little difference than do things like this...
    Jan 2008
    Ya same servo, exact same pump I have used many many times
    Oct 2006
    Quote Originally Posted by V-AC728 View Post
    The fuel door area should always be dry because the runoff hole is placed in the neck itself near filler hole so overfill will run out there and not the filling hole itself. It then runs on the outside of the filler neck, onto the tank itself then onto the ground. If u dont smell fuel inside then u know that the fuel pump cap is on securely.
    Dec 2007
    Ermington, Sydney
    Oh geez indeed mate, that sucks! Hope you find your problem. Bloody VR6's and their fuel issues...
    Oct 2006
    sydney
    dude it happened to my car i runs down the filler onto the the top of the tank then down. i filled mine up too much trying to get to a even dollar on the pump.. i came saw it pissing out so i waited and tryed to see where it was coming from and washed it away. I then got home and tryed to pin point the leak but nothing was loose or split
