So you've basically made a way for a pod to fit inside a stock airbox, correct?
Interesting...
Recently I have noticed my fuel consumption has dropped ,currently I avg 12.5L/100 daily, 17.5L/100 floored around the block and heavy traffic 22.5L/100![]()
I am not expecting this is going to give me much a difference, but a $6 Experiment wouldn;t hurt.
So I bought a 3inch "L" shaped PVC from bunnings pressure fitted into OEM swiss cheesed air box and silconed it on.
Than this is what I got.
So now everything is bolted on
Verdict:
Well... actually give me time. I am going to add a full tank tomorrow, result will be out ~ a week.
But performancewise I feel less torque but more power if that make sense to anyone. Not exactly sure if my mind is playing tricks on me or what not, I honestly did feel more power especially after 3000 RPM.
However, one trade off is the induction noise. The sweet soundofav6 sounded muffed, it produced a lower pitched rumble during hard acceleration after the mod. Think of the induction noise after the mod as an idling V8 during heavy acceleration however with only the pod, the induction noise sounded lot more beastly and more aggressive but less "power".
In essence, this experiment is attempting reveal if a heat shielded pod will give better fuel consumption than a non heat shielded pod. So subscribe to this thread. Fuel consumption result would be out in about a weeks time.![]()
Interesting...
Yeah basically... it fitted flush into the box![]()
Yeah I thought countless times about doing this, I must say I was too scared to lose my noise
LOUIS where is your signature gone?! haha
The noise can attract the wrong attention
Still if flow is good and the stock airbox should hopefully act as a semi-decent heat shield. Looking forward to seeing the results of your experiment.
Oh and clean your damn filter dude!!!!!!!
Looks good, I notice your missing the ghetto hoodlift mod though![]()
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
Ohhh so that's why you were at Bunnings! I called you when you were there as I saw your car. I was in the area
Just my 2 cents: the design of the airbox is partly influenced by the movement of air going towards and through the AFM in the intake pipe. Basically it'll be most efficient this way, in terms of being able to meter the correct volume of air for the combustion process. Air will be channeled so that it will travel with as little collision as possible.
From what I know and can see, using a pod filter distorts this, but apparent change in performance/response/induction noise is due to a less restrictive system.
What you're doing may help in reducing intake air temperature, but will be more restrictive (reduced induction noise in your case?) and might still not be any more efficient than an open pod... my thoughts anyway! I'm not exactly sure that I'm correct with what I just written down though.
Edit: By the way, if you're still awake, I'll just let you know now that I might give you a call about after lunch tomorrow!
