Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Is this normal? Possibly dying alternator?
    Gosford Central Coast NSW
    Quote Originally Posted by V®6 View Post
    Sorry guys another noob question
    I've noticed whenever I start my car, the dash and headlights usual sit at half power until the car gets to about 40km and they then light up fully.
    Is this normal for my VR or would it be safe to say something is wrong??
    check your belt tension. sounds like the accessory belt is slipping/virating too much at low revs to charge properly... as you speed up (engine speed increases too) it tensions up enough to work.
    check that there is reasonable tension on the belt when the car isnt running, and check that the belts not flapping around while at idle.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    checked the belt and had a good look at idle. There is good tension there and I can't hear or see anything flapping around
    Do you have a multi-metre you can use?
    Might be worth seeing what your alternator is doing.
    http://www.cardomain.com/id/sydvr6
    Subaru WRX Wagon 06 + Peugeot 306 GTi6
    I'll have to borrow one but I'll give it a go on the weekend
