2) Check the Transmission Mount to the Frame. The stock ones are a rubber mount filled with fluid, If you are looking at the engine it is located at the rear right. Mine has started to go (can tell by same symptoms and fluid around the Mount)
Solution replace mounts. I strongly recommend not the OEM fluid ones. Try purchasing off
www.dubaddiciton.com.au they will look after you.
3) common problem if the plastic connector between the cable and mech is broken go to a dealership and request a new one. They have rectifyed the problem and are made with Metal connectors now... approx $150+
4)Radio - Easier to replace than to find codes. Hit up Supercheap auto or something for just a head unit unless you want to pimp out her ride.
5) No cover on spare wheel hole. Just go to bunnings and DIY. Or go to a German or European Wreckers near you. I'm in Qld and can't reccommend anyone down there but i'm sure that the NSW boys will help you.
6) I have just done this repair today. Mine had to be replaced because of leaking power steering fluid and was a little bent. But the Steering Rack can either be replaced or fixed. Replacement from wreckers your looking at approx $225
P.S I could be wrong and If I am someone will correct me. I'm only new to this but this is what I have come across and found to be the problem.
Come on guys Lets see how much I have learnt..... rofl
