Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 110
Thread: New VR6 owner
  1. #51
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by V®6 View Post
    I think my headlights must have come from Ebay then also as I have noticed them get a little bit of moisture too at times.
    To get the side repeaters off, just get a flathead and tape the edge so as not to harm your paint, and pry the indicator unit out from the top or bottom (don't remember..)it'll pop out and you can pull it out. then twist the light-globe housing and pop that out too.
    As Branko said, just grab some silicone and re-line the edges of the seals with silicone to mask up any holes
  2. #52
    Sep 2006
    West Sydney
    Get a flat-head and wrap it with some masking tape, then carefully pry off the indicators from both sides. You can apply some force if they don't budge, as long as you're careful with the paint.
    Quote Originally Posted by Golf Houso View Post
    I think I have a major problem here though:
    Every piece of lighting equipment that comes off Ebay does that, even one of my front indicators !
    some clear silicone should fix that up...
    Yeah, use a blow-dryer to get rid of the condensation, then seal up the bulb holes with masking tape, and apply some silicon (any will do). Wait overnight then attach back onto car
    Edit: Dammit Mickey, you're everywhere.
  3. #53
    CHeers for the help guys. If I can get a moment tomorrow I'll shall try to take them off the car.
    Also I am close to having my fog lights hooked up. I've got a 30A relay, the fog lights themselves and European Fog light switch. Just have to get the wiring harness at can get it under way.
    How do I take out the dummy fog lights?
  4. #54
    Sep 2006
    West Sydney
    Again, a wrapped up flat-head From the sides as well.
  5. #55
    Jan 2007
    Quote Originally Posted by rayray086 View Post
    And if you don't have that use the car key, I use that for everything from car repairs, screwdriver(both), box-cutter and even as a knife!
  6. #56
    Sep 2006
    West Sydney
    Be careful with that though - silly me used too much force and bent one of my keys slightly Still works though; it's just a more tighter fit.
  7. #57
    Jan 2007
    Jeez thats no good, mind you you can always bend it back without too much of a problem, its still rather useful though ...
  8. #58
    Nov 2006
    Central Coast, NSW
    the reason the water gets on the inside of the headlights is because of the difference in temperature fro mthe inside to the out. if you put a hole at the back (in the plastic) with little plastic tube hanigng out, the temperature stays the same and the rain water doesnt get in.
    otherwise, seal it up with silicone
    as soon as i got my side indicators off ebay I pulled em apart and resealled them properly with silicone.
  9. #59
    Nov 2006
    Central Coast, NSW
    oh the resprayed stuff looks freakin sweet by the way.
  10. #60
    Cheers again everyone for the compliments
    I know I sound like a total noob here but where is the fuse box??
