new to coilovers
Hey i got hot tuning coilovers a few months back and once they were fitted the back makes some noise, it sounds like my suspension is broken but its not, even the slightest bump makes a heck of a racket. I want sure if it was maybe the setup of each strut. I have the small spring at the bottom and the big spring on top, I've asked a few of my pals some say it right but others say it should be the other way around?? I have no idea whos right or if its something else completely, bushes or mountings maybe?? any help would be great.
The location of the helper spring doesn't matter. Some manufacturers have them on the bottom, some on the top, either way they'll still do their job of keeping the spring in place at zero load.
Coilovers are a lot stiffer than your average stock standard spring and shock combo, so they place more stress on the other components of the suspension. What you may be hearing are the other parts of the suspension gradually wearing out. It's recommended that you change the rear strut mounts when you fit in new suspension. Same applies to the fronts too, but I'm guessing you're not having any problems at the front (yet) as you haven't mentioned it.
Also, it may not even be suspension related. I've noticed that **** in the hatch tend to jump around a bit more when I had my coilovers installed. Make sure stuff under the carpet (spare wheel, tools etc) are strapped down well.
cheers il have a look in my boot and see whats in it and have alook at my suspension tomorrrow need to raise it up a bit too many speed bumps around my area lol
- You may not post replies
- You may not edit your posts
Forum Rules
