I think it might be something to do with the sparkys or leads
or some thing to do with the spark because obviously when the car is cold the fuel is harder to com-bust
I'm a little concerned with the VR6.
When i start the car on a cold morning or when it hasn't been started for hours, the car bogs down when i try taking off for a while. For example i will acelarete and the car wont move then as the rev's drop it will move forward and this will happen for about 5-10min then she's right. Then every know and then it will still bog down under load on take off.
WFT is wrong with her?
This may be the cars anti-thrash nanny system kicking in.
Basically, the engine will refuse to rev hard when the engine is cold. By what you describe, you may be putting the boot in a little too early!
Be nice to your VR6 and let it limber up before mashing the loud pedal![]()
I remember when I first got my Vr6 this happened once when I tried to give it stick first thing in the morning. almost felt like the 'anti thrash' wouldn't let you. Definitely be kind first up.
1983 Lotus Esprit Turbo
2013 VW Golf MkVI Cab
Looking for a blue MkIV R32.....
Check the oil temp on the mfa. once its up to 50, you can go hard.
Nah im not thrashing it when its cold man, it literally happens even if i just take foot off the break to let the car roll forwards too.
I have new leads and spark plugs, ganna change coil pack too so hopefully this will sort the problem out.
Anyone else have the same problem before?
Get it scanned and see what codes it has.![]()
when u come past my place to get that wheel arch trim bring it along and we can scan it for fault codes. i have a vag-com
I dont think there is an anti thrash cuz there have been times when ive been in a rush and whilst havnt redlined it i have driven softly and nothing tlike the above mentioned happens??![]()
