Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: N/A Chips
    nt
    N/A Chips
    Wondering if anyone has any experience with chips such as this: OBD1 VR6 Performance Chip - Stage 1 - Dubforce Tuning
    and if they actually work significantly and have noticeable increase in performance. (Of course i know not anywhere near as much as actually turbocharging etc).
    Jun 2011
    Couple of dudes are running the ebay powerchips, obd2 though. They say they are worthwhile. Best part is 7200rpm
    I tried a 'abt' chip but it made a relay buzz under the dash when turned to accessories.
    Whether incompatible chip or dodgy soldering i do not know. I do know that the problem is with the ecu code with have. Which is bespoke to Australia, at least what i have found thus far.
    Jun 2013
    Melbourne, Australia
    Search GIAC chip tuners in Melbourne. There's a tuner (sorry can't remember name) that can socket your ECU (OBD1 or OBD2) and provide a chip.
    Basically means you can swap chips from tuned to stock.
    There's a member here that had it done. I'll try and find out which tuner it was.
    2012 - Tiguan - 155TSI - DSG - Black
    Jun 2011
    Problem with giac ones in Australia is they cost $800
    Steve had one? And so did pete but his pinged with a mk4 headgasket
    Jun 2013
    I looked into the eBay ones and read that you have to either send them your ECU to socket it or they provide a new socketed ECU and the postage was horrendous. That's why I decided to look into Australia based tuners.
    May 2014
    Newcastle, Australia
    The dubforce obd2 ones are some of the only affordable chips available for our obd2 ECU code, it is the same as the UK code. I'm about to order the "stage 2 obd2" chip. It is still 300 bucks but 800 for an n/a chip is just stupid, that's cams and exhaust money.
    Jun 2011
    All early ecu's half of 95's included will need to be soldered or socket-ed. Auto leccies can do it. Just 28 pins. Sockets are like 5 cents each.
    For the cost of giac i will have a running stamdalone ecu that will make more power and can allow alot of functions
    nt
    So considering i have OBD1 and haven't touched the ECU or anything like that yet... What do you suggest i do? Can anyone provide some links for info on everything i need to do to run a chip?
    Thanks
    Jun 2011
    Buy a chip and cross your fingers
    May 2014
    Get to you ECU and find its code, buy it send them the code, go to auto electrician get it soldered.
