Results 1 to 6 of 6
Thread: mysterious oil leak
    Jun 2006
    mysterious oil leak
    on my gf's golf, it appears to be leaking from the oil sensor, the one on the right hand side, just below the oil cap. but not next to it, i mean literally through the brown plastic mass, wtf?
    marked on the photo
    ideas?
    ill try to replace it and see how we go, but why would it do that
    Feb 2006
    Camberwell, Victoria
    Dude, they break...
    Go to vw and get a new one, screw out the old, in with the new and you'll be right...
    Happened to me and only cost like $20...
    Jun 2006
    cheers sean, didnt know thos thing break, i guess u learn something every day
    Camden, Sydney
    Where the metal pin goes throught the plastic resin, oil works its way out. If you jiggle the metal bit, you will see a dribble start.
    Easy fix, I have the sensors in stock if you cant get one nearer.
    Feb 2007
    definately the oil sensor, i changed mine, hard to get exact same part, works the same , but yeah, under 20 bucks isnt bad for genuine parts
    Jun 2006
    thanks matt, i got one already
    problem fixed
    cheers
Similar Threads
  1. coolant leak!!!!
    By GoLfMan in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 04-03-2007, 01:35 PM
  2. Mysterious Intermititant misfire. :?
    By ScienceVR6 in forum Mk3 Golf & Vento
    Last Post: 19-02-2007, 07:28 PM
  3. Mysterious *BEEP*
    By KI11Z in forum Mk3 Golf & Vento
    Last Post: 22-11-2006, 08:42 PM
  4. Injector Pump Leak and movement - Main Shaft
    By hvellacott in forum Diesels
    Last Post: 28-09-2006, 07:20 PM
