Results 1 to 10 of 12
Thread: Mysterious Intermititant misfire. :?
    Feb 2007
    Bunyip, Victoria
    Occationally, my VR6 gets a bad misfire, and losses power under load, and then clears up and runs fine and gets full power. I dont know the age of the plugs or leads. When is the scedualed change of plugs and leads?
    mine has done 137,000km.
    Could it be anything else?
    Mar 2006
    Tas
    Maybe need a new coil pack?
    Sep 2006
    West Sydney
    Quote Originally Posted by ScienceVR6
    Having the exact same thing, except in a 2.0L. Doesn't happen regularly, but once in a while either during second gear or fifth gear (coincidence perhaps). I have no leads to what may be causing this either
    Camden, Sydney
    Coil pack on Vr6 and coil on your car Ray.
    Sep 2006
    West Sydney
    Thanks. Is this a common problem?
    Mar 2006
    Tas
    This is common from what I hear.
    Replaced the coil at 90,000km in my old Mk3 GL after suffering similar symptoms. Easy, quick and cheap part to swap over yourself.
    Oct 2006
    sydney
    do you apply acceleration and it doesnt move next sign of the fact its a coil is that it will turn off itself while driving or not start at all no matter how manytimes you try its common mate i suffered with it for ages
    Feb 2007
    Coil Pack and Oil Pump
    My VR6 had a bad miss few years back, Seb at Euroauto replaced my coil pack and it ran like a dream.
    Only recently however, it developed another slight miss, this time Oil-Pump, Seb replaced this for me and once again running like a dream
    http://euroauto.com.au/
    Peregian Beach
    My Seat has been doing the same thing and it was diagnosed as the coil this morning. I have purchased a new one from VW - $263.00! I haven't fitted it yet so I don't know if it has fixed the problem.
    Feb 2007
    Bunyip, Victoria
    it went from being an intermittant missfire, to a full missfire on cylinder 1. Discovered big blue spark eminating from the lead around the plug cap. i've ordered some leads from Repco, and hopefully it fixes it. Removing number 1 lead makes no differance to the running of the motor so im assuming that this is the cause of the missfire.
Similar Threads
  1. MK4 GTI Misfire
    By MK2 GTI in forum Mk4 Golf & Bora and New Beetle
    Last Post: 10-02-2007, 08:34 PM
  2. mysterious oil leak
    By deemoE36 in forum Mk3 Golf & Vento
    Last Post: 10-02-2007, 03:00 PM
  3. Mysterious *BEEP*
    By KI11Z in forum Mk3 Golf & Vento
    Last Post: 22-11-2006, 08:42 PM
