Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: My VR6T
    Point Cook, Vic
    As everyone has said its awesome to finally see some details of the setup posted on the net!
    Looks like you have invested some big dollars into her.
    Whats your view on your turbo choice after the fact? Are you happy with how it comes on or does it spool too fast for a fwd? If you had your time over would you pick the same turbo again?
    Ive been slowly piecing together my own setup and im still stuck on which way to go.
    FOLLOW US ON FACEBOOK
    Jun 2008
    Hobart, TAS
    Damn this thing looks tits!
    Need to get some footage of this thing in action!
    Nice work, how is it in terms of reliability?
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Sep 2006
    West Sydney
    Very very cool
    Aug 2007
    Quote Originally Posted by Tim View Post
    I was looking at the GT28rs, which would have come on earlier but according to my turbo advisor said it may choke up a little at higher rpm.
    So i went with the GT3082R, first of i had a 1.06 exhaust housing but that didn't make full boost till about 3700. I now have a .82 and it is at starts boosting at 2500ish and full boost by 3300ish.
    Reliability, its a custom high power VR6.
    I had some clutch shudder issues on the new clutch, pulled it out and basically re-made the clutch plate and it is much better now.
    Cooling system seams to be fragile in the heat, 40C plus bu that can be said for a lot of VR6's.
    Have only broken 1 inner CV joint, that was at Portland VW drags earlier in the year. On semi slicks changing into second.
    Not to bad really.
    1979 Mk1 Golf 2door (Under construction)
    1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
    2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
    Feb 2008
    mOOROOLBARK
    what did you get down the quarter.
    Eastern suburbs of Melb
    FINALLY SOMEONE HAS DONE THIS AND DOCUMENTED IT!
    Good job mate!
    Aug 2007
    Unfortunately Portland is 1/8 mile, which the car is not really suited to imo. Best time i got was 8.8, but had problems all weekend with missfires and didn't have traction control at the time.
    Jan 2008
    Newcastle, NSW
    Awesome work! Thanks for posting up the details
    Aug 2007
    Well I had the opportunity to take some more photos of the turbo and manifold setup this week due to having to remove the turbo to repair the turbo coolant hoses that had been affected by the heat. The high quality coolant hose that I had used just went hard and crack causing a nice steam haze on the way to work on wednesday.
    They give you a better idea of how tight it is behind the engine when you put a GT30 back there.
    Feb 2008
    mOOROOLBARK
    are those tri clover clamps i see there
    iv never seen them on a car before
    thats a good idea for ease of removal
