If your AC is working, USE IT! Running the AC regularily (even in winter) seems to keep everything ticking along longer.
Keep in mind, even if you buy yourself a mint looking vr6, dont be suprised if something expensive breaks and needs replacing
I thought I got a bargain (and i still do) on a very clean, completely original, 90000km with a service history showing services every 5000km, ac cold enough to give frost bite and heater hot enough to melt the plastic vents, 4/4 windows working, ect. Still had to fork out well over a grand at its first service to fix up a problem with a leaking fuel rail or something amongst other little things. Not a cheap car to run, but worth every cent in my mind![]()
Thanks man, I understand with age these cars need tlc especially the common issues like window regulators, etc. I'll keep my eyes pealed for a good condition one. Cheers
yeah I am already calling mine the black hole - i.e sucking my money away! But they are a fun car to drive and in a way a good car to mod, you don't feel so bad spending money on upgrades when they usually replace played out old parts on the car already!
when you dont use the air con for a good while, say during winter the seals dry out
then when you go to use the ac again when its hot the seals die and your left with a dead one![]()
Wide Steelies For Sale
http://www.vwwatercooled.org.au/foru...ies-76972.html
Yeh pete, this is a common problem in a lot of cars, I have had air con problems in other cars with seals gone bad.
