So I was bored one day at work and found this little strip of flexible white LEDs on ebay...
http://cgi.ebay.com.au/White-12V-96-...QQcmdZViewItem
I was actaully looking for some interior lighting to put in the boot for my stereo install but 10 Minutes previous to that, I was also admiring the Audi R8.... does anyone get where I am going with this?
Mk3 Audi R8 Golf FTW
kgo!
Yeah!!!!
Parkers only:
Main Beams:
This is how I wired it up:
1. run power wire from both lights through the fire wall and up behind the dashboard.
2. pull out lighting thingo (i believe it is called a loom?)
3. turn lights to the 'parker' position
4. use a vu meter to work out which pins are for the parker lights
5. jam the wires into the back of the connector
6. re-assemble
Here you can see that I'm holding the power wires for the light strip
and here is a better example of where the wires go
don't hold me to it but i believe the one further to the left is the negative.
I don't think the pictures really do them justice, because they look sweet in the night.
Opinions are more than welcome![]()
