28-07-2013, 12:33 PM
#321
My New VR6 *Little Update Thread*
After an unexpected phone call this morning I had to prematurely put my 'joke' wheels back on before my rear spacers showed up.
I'm at the point where I need to cut out my helpers to tuck tyre. Not sure what has happened as I used to tuck a 165/50/15..
With the addition of a much faster car to my collection, I will eventually build a motor for the vr and turn it into a 1/4mi. (Sometimes circuit) mobile.
Rough plans are large cam's (TT28
hopefully use a chipped ECU before resorting to the standalone setup I have in the shed, find someone to do decent head work and a good valve job. Run stock block re-ringed and mk4 head gasket. (Hopefully find a decent 2.9 block cheap, would be ideal but unlikely)
Bought a 42DD test pipe, should be here soon. And then will hopefully get down to WSID for a run and see what happens.
"I only post on Facebook if I know i am going to get likes" - M
30-07-2013, 11:01 AM
#322
Adaptec spacers turned up this morning so chucked them on:
Pretty sweet setup IMO for those who can't afford expensive or 'hellaflush' wheels. Or those who don't want to run an aggressive setup.
31-07-2013, 07:08 PM
#323
What's size are your adapters Hayden?
Something new
31-07-2013, 08:09 PM
#324
20mm front
30mm front (aggressive flare job)
I'd go 20mm rear and 15mm front if it was on a stock-ish guard.
31-07-2013, 08:28 PM
#325
Yer look really good in your car, looking up sizes to fill my guards a bit more
Something new
31-07-2013, 08:34 PM
#326
Spacers on the stockies make it look a lot better. Vr wheels are a cool oem design.
Did you go to 5 stud?
31-07-2013, 08:48 PM
#327
Yer makes the vr conversion so muh easier
Something new
31-07-2013, 09:05 PM
#328
Dude you run out of paint when you did your wheels? Or not checked the caps before you started spraying? The colours are all whack!
31-07-2013, 10:06 PM
#329
Ha ha ha looks cool as mate! What size tyre are you running mine look massive compared to yours.
31-07-2013, 10:11 PM
#330
Feck you A.
They are a 195/50/15. I was only thinking today how ridiculous a stock 205/55? Would look..
- You may not post replies
- You may not edit your posts
Forum Rules
