Finally got a chance to do the abs. In between the ****ty weather and other nonsense.
Ended up being around 2kg's. Still has the speed sensors in the hubs.
Local scale is accurate to 20kg. Which is annoying so was going to wait till drags.
Got a lightweight battery yet? You are reaching the end of all possible weight savings ahaha.
It's so impressive the build and detail on that car.
But this is my fanboy clip.
Root beer VR6 12.43@111: Root beer VR6 12.43@111 - YouTube
Thought i would add a photo of the car as it sits as there isn't any. Because it looks like ****.
Started removing some seam sealer, wire wheels I bought are useless so used a chisel was bit of a pain but not the worst. Little corner section behind the tail light is all I done and there was 0.5kg's rest of the car and probably get 2.5kg's.
Tps wiring finally split so I need to cut and solder that.
