Page 46 of 56 FirstFirst ... 364445464748 ... LastLast
Results 451 to 460 of 556
Thread: My New VR6 *Little Update Thread*
  1. #451
    Jun 2011
    Local scale is accurate to 20kg. Which is annoying so was going to wait till drags.
  2. #452
    Jun 2011
    Finally got a chance to do the abs. In between the ****ty weather and other nonsense.
    Ended up being around 2kg's. Still has the speed sensors in the hubs.
  3. #453
    May 2014
    Newcastle, Australia
    Got a lightweight battery yet? You are reaching the end of all possible weight savings ahaha.
  4. #454
    Jun 2011
    Quote Originally Posted by cliftronix View Post
    Got a couple in mind. Was leaving it till last minute so it doesn't go flat when i go to race it.
  5. #455
    May 2014
    Just watched that guys vids, that thing is sick. My dads an elec engineer and if you needed the caps charged before use he has some things at work that would be able to "safely" ahaha.
  6. #456
    Jun 2011
    Cousin only sent me that picture, i haven't looked further into it. Idea would be just have extension/terminal adapters to swap regular battery to those at the track.
  7. #457
    Aug 2006
    Melbourne VIC
  8. #458
    Jun 2011
    Quote Originally Posted by Water Boy View Post
    It's so impressive the build and detail on that car.
    But this is my fanboy clip.
    Root beer VR6 12.43@111: Root beer VR6 12.43@111 - YouTube
  9. #459
    Jun 2011
    Thought i would add a photo of the car as it sits as there isn't any. Because it looks like ****.
  10. #460
    Jun 2011
    Started removing some seam sealer, wire wheels I bought are useless so used a chisel was bit of a pain but not the worst. Little corner section behind the tail light is all I done and there was 0.5kg's rest of the car and probably get 2.5kg's.
    Tps wiring finally split so I need to cut and solder that.
