Page 48 of 56 FirstFirst ... 384647484950 ... LastLast
Results 471 to 480 of 556
Thread: My New VR6 *Little Update Thread*
  1. #471
    May 2014
    Newcastle, Australia
    When do you get the car back from Newcastle Dyno Centre? What power do you hope it makes once tuned? And what does it weigh now after all your interior trim removal?
    I saw a burgundy Mk3 VR6 at Kotara on Sat - actually i heard it before i saw it . You can't miss that sound.
    That must have been me ahaha.
  2. #472
    Jun 2011
    Quote Originally Posted by Water Boy View Post
    Think a lighter battery could be on the list!
    Whale penis!
    http://pages.ebay.com/link/?nav=item...262520&alt=web
    Going to get this one. Reviews seem to be pretty positive and it's an Australian company. There is ssb batteries that weigh a measly 700g that have the same specs as a standard battery but are $400 odd dollars.
    I should get it back on Tuesday, if not Wednesday this week.
    I haven't a clue what power it should make, i take dyno numbers with a grain of salt these days anyway. Only went this way as i need more than 6500rpm to finish 1/4mi in 4th instead of a 5th gear change.
    Realistically it 'should' pick up 5-8kw (135fwkw) would be happy with that. Any more and i would have a smile on my face!
  3. #473
    Jun 2011
    New graph.
    Old for comparison.
    Pain in the arse there isn't one on new sheet.
    It made a whopping 2.5kw more than a standard ecu! Surely this could now prove that chips don't do anything..
    Guessing just conservative tune, judging by how reserved the dude is. Does go a bit harder in the middle. Spins 1st, 2nd and 3rd when planting it mid gear.
    Needs touching up a bit cause the idle fluctuates a bit and when just tapping the throttle to take of it just hesitates and dies.
  4. #474
    Sep 2006
    Parkinson / Brisbane
    that's decent bro! have you run this thing over a weigh bridge yet??
  5. #475
    Jun 2011
    Quote Originally Posted by KI11Z View Post
    Not even. really thought there would be more in it.
    Not yet. Will get a weight from the one at the track
  6. #476
    Aug 2006
    Melbourne VIC
    Do you mean standard ECU vs chip or standard ECU vs MS?
    Because when I look at the above graphs its your chip vs MS?
  7. #477
    Jun 2011
    Car never ran on a chip.
    Gain is from standard ecu to ms.
  8. #478
    Aug 2006
    Melbourne VIC
    Ahhhhhh ok.
  9. #479
    Sep 2006
    hm, true, like you said, maybe a conservative tune? did you ask them for an aggressive tune?
  10. #480
    Jun 2011
    Just said make it make power lol.
    Plugged a laptop in and the acceleration enrichment isn't even turned on. So that will be the tip in throttle problem. Will tune that on the weekend at the local racetrack/industrial estate.
    It also now has a huge exhaust leak from the manifold to downpipe. So that will cause some greif too.
