Page 45 of 56 FirstFirst ... 35434445464755 ... LastLast
Results 441 to 450 of 556
Thread: My New VR6 *Little Update Thread*
  1. #441
    Feb 2013
    Brisbane, Australia
    Finally got manual regulators that weren't going to cost me $400 so put them in, removed the power windows wiring and the side intrusion bar.
    Weight saved ~5kg with the foor inner cut out should be around 7kg saved, per door!
    Here i was thinking i was running out of free/easy reductions.
    This weekend i will be removing the front sway bar.
    I thought you had plexi windows?
    '15 Polo GTI
    Past - '95 Mk3 VR6 Colour Concept
  2. #442
    Jun 2011
    Quote Originally Posted by himynameisbryce View Post
    Only for the rear doors and hatch, need fronts functional as there is no fan unit in the car plus no carpet means it gets real hot in there
  3. #443
    Aug 2006
    Melbourne VIC
    Im guessing airbags have gone?
    Roof liner?
  4. #444
    Jun 2011
    Quote Originally Posted by Water Boy View Post
    Roof liner?
    correct. Just need to scrap off one more section of the carpet stuff stuck to the skin.
  5. #445
    Jun 2011
    Ripped off the rest of the stuff on the roof. Procrastinated, then manned up and pulled the front sway bar.
    Nice bit of weight saving!
    Control arm bolt for more content.
  6. #446
    LAUNCESTON, TAS
    Yeah just saw your wheel specs. 8.5 would be nuts..
    i have 8.5's +35 on the back of mine man and they fit pretty shmick!
  7. #447
    Jun 2011
    Quote Originally Posted by heysie View Post
    Wisened up since then.
    9" +16 fits nice.
  8. #448
    Mar 2012
    Central Coast, NSW
    Too bad you sold them! Silly bugger
  9. #449
    Jun 2011
    It all started swapping spacers. Which i didn't even do. Cut the metal out from the other door, then said stuff it. Lets do the dash.
    Removed everything behind it. Got rid of the power windows loom and cut most of the radio loom out.
    going to remove all the abs wiring while the dash is out tomorrow.
    Saved a bit over 16kg's.
  10. #450
    Going to throw it on the scales when done? Be keen to see how it compared to stock advertised weights
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
