Wow finally! nice work![]()
The out lining figures for the graph are weird? (Graph shows it only revved to about 6200, but it clearly got revved to redline).
But yeh that power shift seems about rite for the cam you've got, your lucky cause your ecu is handling the changes, if it didn't your AFR and power curves would be quite rough/spiky and wouldn't have made much more than me.
Only fellar I got told about who did head work was dubsteves car, port work and 268 iirc, made 111kw, ecu couldn't handle it, thousands of $$ for nothing.
Have u got a different gear set in your Gbox or did u do just the ring a pinion swap and LSD ?
