Page 33 of 56 FirstFirst ... 23313233343543 ... LastLast
Results 321 to 330 of 556
Thread: My New VR6 *Little Update Thread*
  1. #321
    Jun 2011
    After an unexpected phone call this morning I had to prematurely put my 'joke' wheels back on before my rear spacers showed up.
    I'm at the point where I need to cut out my helpers to tuck tyre. Not sure what has happened as I used to tuck a 165/50/15..
    With the addition of a much faster car to my collection, I will eventually build a motor for the vr and turn it into a 1/4mi. (Sometimes circuit) mobile.
    Rough plans are large cam's (TT28 hopefully use a chipped ECU before resorting to the standalone setup I have in the shed, find someone to do decent head work and a good valve job. Run stock block re-ringed and mk4 head gasket. (Hopefully find a decent 2.9 block cheap, would be ideal but unlikely)
    Bought a 42DD test pipe, should be here soon. And then will hopefully get down to WSID for a run and see what happens.
    "I only post on Facebook if I know i am going to get likes" - M
  2. #322
    Jun 2011
    Adaptec spacers turned up this morning so chucked them on:
    Pretty sweet setup IMO for those who can't afford expensive or 'hellaflush' wheels. Or those who don't want to run an aggressive setup.
  3. #323
    Jun 2012
    wollongong
    What's size are your adapters Hayden?
    Something new
  4. #324
    Jun 2011
    20mm front
    30mm front (aggressive flare job)
    I'd go 20mm rear and 15mm front if it was on a stock-ish guard.
  5. #325
    Jun 2012
    wollongong
    Yer look really good in your car, looking up sizes to fill my guards a bit more
    Something new
  6. #326
    Jun 2011
    Spacers on the stockies make it look a lot better. Vr wheels are a cool oem design.
    Did you go to 5 stud?
  7. #327
    Jun 2012
    wollongong
    Yer makes the vr conversion so muh easier
    Something new
  8. #328
    Mar 2012
    Central Coast, NSW
    Dude you run out of paint when you did your wheels? Or not checked the caps before you started spraying? The colours are all whack!
  9. #329
    Feb 2010
    Ha ha ha looks cool as mate! What size tyre are you running mine look massive compared to yours.
  10. #330
    Jun 2011
    Feck you A.
    They are a 195/50/15. I was only thinking today how ridiculous a stock 205/55? Would look..
