Page 27 of 56 FirstFirst ... 17252627282937 ... LastLast
Results 261 to 270 of 556
Thread: My New VR6 *Little Update Thread*
  1. #261
    Aug 2012
    Kangaroo Valley, NSW
    You know it. Going to see if I can get my username changed to 'BrianSpilner'
    :rofl:
  2. #262
    Jun 2011
    Got to go for a squirt with the new throttle body.
    And for such a minor mod, it was definitely rate able on the butt dyno. Throttle response is much better, whole rev range seems to go bit harder to.
  3. #263
    Jun 2011
    So, yesterday my clutch pedal got stuck on the floor! Once I pulled it up I tried pushing it again, this time it stopped 3/4 of travel and shook up and down quite violently. turned the engine off. now i can only push it back half way of travel.
    Any one have any ideas. At first I just thought the pedal broke. No big concern. But after a bit of a look I fear something more sinister at work.
    This is a broken pedal. Note the metal has cracked exposing the white clip.
    This is mine. No broken welds or anything.
  4. #264
    Fingers on the pressure plate? This happened to me ages ago in a Ford Laser (pedal went lifeless and on the floor) and it was the pressure plate.
  5. #265
    Jun 2011
    I'm thinking this has when I had the ratios changed. The car was hard to put into 1st every now and then and every other gear was similar to pushing through thick goo. At the time I though they just mis aligned the shifter cables.
    Any idea how to test this? I.e start it in first and see what happens
  6. #266
    No idea Hayden. In my case, about 6 of the fingers on the pressure plate broke off when i changed gear. Clutch was fine one second and lifeless the next (no noises etc to warn you).
    I had to buy a new clutch kit.
  7. #267
    Jun 2011
    Seems exactly what happened.
    Annoyed as its a brand new kit that should hold up 400ft/lbs and 7000rpm launches haha.
  8. #268
    Aug 2012
    Have you tried the little spring on the back if the clutch?
  9. #269
    Jun 2011
    Quote Originally Posted by Smeeeb View Post
    Back of the clutch pedal? Yes that is fine also.
  10. #270
    Aug 2012
    Ok that's what was up with dads clutch.
