Re your PM
The mystery plugs:
Yep, this one is part of the fuel rail loom. If you have the correct rail, this is incorporated with it. If not, let me know and you can have one of mine for cheap.
Yep, radiator fan plug (comes from the fan control relay unit as per the 8v)
Can't remember these ones, but there are no major sensors on that side of the car, so just leave them til last
This should be for the reverse light switch on top of an 02A gearbox. You'll need to run it to your factory 020 switch (the colours should be the same)
By the looks of this, you have the alternator exciter wired wrong - it is a single, blue wire, not a black one
I don't even recall seeing that red plug on anything and my memory is good with this stuff. It's obviously a/c related, though
Nice engine - but make sure you ground your coil externally to something otherwise you'll fry it in no time, though
Throttle body is the wrong way around, too.
**Lastly, and most importantly, though, that is an OBD2 ABF and will have a coded immobiliser, so to make it run, you will need the ignition barrel with transponder, the corresponding key, the Siemens alarm relay setup and the matching 037 906 024BE ECU**
