Results 11 to 20 of 21
Thread: My journey for extra HP in my VR6
    Nov 2015
    262 cams, 2.9 clone intake manifold, full metal 3" intake, mk4 air temp sensor, ported exhaust manifolds, 2.5" or 3" exhaust, 3.94 final drive. Done. /thread
    Nice agreed with this one.
    Nov 2015
    Quote Originally Posted by Bug_racer View Post
    Id add Phonelic spacer and LSD to ^ set up as best bang for buck . Then reduce weight like crazy . to remove 300kg isnt so hard .
    Not a bad idea, user root beer had a great N/A thread on another forum, he's managing 12.5 secs to do 402M.!
    Jun 2011
    Quote Originally Posted by Mustillo View Post
    12.43 actually
    Nov 2015
    Yeah, all good ideas, but I'm going to hold out and drive it stock while I save. If I still really want to make more power, I will take the engine out, do the chain, new MkIV headgasket, CAMS, springs, rebuild etc.
    Feb 2008
    mOOROOLBARK
    Plus one for this comment!
    May 2010
    Plus 2 for this comment. Hayden has been playing the vw game for a while and has an intimate knowledge of all things mk3. Don't waste your time with other stuff, just do this and save yourself time/money and actually get results
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
    Jun 2011
    Quote Originally Posted by Speed View Post
    Aw shucks.
    Sebs right, lsd with 3.94 is very helpful. But that starts to get to expensive for most people.
    May 2010
    I'm yet to source a clutch and flywheel for our cabrio project. Will a lightened flywheel give her more zip and how light?
    No idea what a stock one weighs.
    Apr 2011
    A lightened flywheel will lower the resistance to rotational acceleration (and thus moment of inertia) which will give you more 'zip' or an engine which will rev more freely (quicker). Downside to this is when you're cruising the engine will lose revs quicker because you have less momentum energy from the spinning flywheel as well as a slightly rougher engine feel as the heavier flywheel normally dampens engine vibration to an extent.
    A stock VR6 flywheel is 18.5lbs or 8.5kg. A lightweight flywheel weighing around 10lbs or 4.5kg is as low as you would go so anything in the range of 10lbs to 18lbs should give you net gains.
    I highly recommend anything from ClutchNet.
    Hope this helps,
    Tim.
    Jun 2011
    Clutchnet stage 5 is the goods. Drives like stock. But when you snap gears, you know it's grabbing.
    Autotech 13lb flywheel is cheap and still great for street. Makes the car so much better, vr's are real lathargic with the standard boat anchor.
