Results 1 to 10 of 18
Thread: My car wont start and stay running!
    Feb 2010
    Warnervale, NSW
    Ok so with increasing frequency my car will not start.
    It turns over, fires and then dies about a second later. Keep on trying and keep on trying and eventually it just starts and runs fine. It never dies once its running ok.
    But getting it to start can be a PITA.
    I cant trace it down to water or anything like that. Wiggling the ignition switch does not help. It is just tempremental and decides to f*** up when it wants to.
    Any ideas? Help!
    My Golf is a 96 GL Classic. (ADY, Euro-spec, Australian).
    May 2010
    Barossa Valley, SA
    If anyone out there has heard of a solution to this I would be appreciative too.
    It's more of a pain in the butt than anything. And yeah, there is no rhyme or rhythm to it, it just randomly won't start.
    Mine is a VR6 MK3 1995
    THANKS.
    Golf MkIII VR6 Colour Concept Yellow
    The starting and cutting out is most likely the immobiliser. The usual fix is to re-rack the pick up plug just below the ignition lock. Take the lower shroud off the column and follow the wires down until you find the plug. Disconnect it and reconnect it.
    Feb 2010
    hey mate, i had a problem similar to this. mine was the key switch amplifier part that sits arounf the ignition barrel (should be brown). i pulled it off gave it a wipe and put it back on. started. i had to to this every now and then till it came more frequent. so i just replaced it.
    its the part which send the signal of the key to ECU to say that this key belongs to this car basically.
    that took me sooo long to figure out when it was happening to me. i used to get real frustrated that it wouldnt start when i needed it to. but would start when just going for a pointless drive.
    let me know how you go. hope my problem helps
    Without Your Seatbelt, You Know Your Gonna' Die!
    Project: mk1 cabriolet 20vt
    Sutherland Shire, Sydney
    make sure u turn off all ur aircon about a minute before you finish ur drive. mine did it heaps and i heard off a mate about the aircon problem, somthing about it puts to much stress on the engine on start-up. since then i dont run aircon if i have to, or turn it off roughly a minute before i get home it starts perfect the next day.
    hope that helps
    95' golf VR6
    Jul 2009
    melbourne
    hey mate,
    if it fires up it could be your cat converter.. mine was blocked n same thing seemed to happen. if it had ne problems before it happened id say unbolt the cat converter n try and see if it runs...
    hope it helps
    Feb 2010
    Warnervale, NSW
    Ive decided its either the amplifier thing, or ignition switch.
    It only does it so imtermittently. 2 weeks good now..
    Camden, Sydney
    THe way to test both is when it wont start, take the key out, turn it over and try again. If it then starts, is probably the reader coil.
    Or when it is turned all the way to the right and it wont start, lift the key at the end of its cycle. If that fixes it, its the ignition switch.
    My money is on the reader coil, or the chip in the key. Do you have another key?? Try it if you have one.
    Feb 2010
    Warnervale, NSW
    Cheers Matt,
    Got myself another project!
    Will see next time it doesnt work. Pretty sure it doesnt work when ive turned it over previously.
    Sep 2009
    wollongong
    Quote Originally Posted by any001 View Post
    THANKS.
    hey man, mines actually at the mechanics, had exactly the same problem, to a point where it wouldnt start at all....
    ended up being the contact switch in the ignition-easy fix
