Sure is. And of course haha
Pretty sure their kamai vents. Not sure where there from.
Sent from my GT-I9305 using Tapatalk
Lorenz old Mk3. Please look after it!
It was always going to happen. Just a matter of time....
What did you get defected for?
1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
Ride height and oil leak
Bugger.
Coilovers? Can you just adjust it back up?
Where is the oil leak coming from?
Yea its on coilovers but that is the problem. There illegal full stop.
Oil leak is from the pcv hose. Its been leaking for a while and its all over my cam cover.
Bummer. Good luck with swapping out the coilovers.
Breather pipe oil leaks seem to be an standard option for the Mk3, always had to replace it on my CL every 5-10 years as engine oil in the exhaust gas eats the rubber combined with wear from engine vibration. The Vento appears to have the same problem as well just a completely diffferent breather pipe design/routing but same cheap rubber connections.
Coilovers should be easy. They will be a straight swap with the stock springs and struts out of the vr6.
Silver golfs still defected but gave the vr some love recently.
Got the coilovers swaped into this, got that pesky suitcase removed and gave it a good old clean.
Sent from my SM-G900I using Tapatalk
