Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: My '98 4Dr CL
  1. #31
    Nov 2010
    Melbourne - SE
    have you taken the height adjusters/spring perch's out of the rear yet? i took them out on my a3 and got at least another 1-1.5" of drop...
  2. #32
    Jun 2012
    SE Melbourne
    Quote Originally Posted by eltonking View Post
    You had JOM's didn't you? CX's are sleeved, so you can only screw it down in the sleeve until it reaches the spring preload collars.
    I wouldn't recommend it, but have you tried reducing the preload on the spring to the point where its a little sloppy, looks like some of the guys on vortex are doing that to get real low, check out the CX racing thread if you haven't already.
    HaydEn, you tried all that though didn't you?
    And as said, wire brush wheel on a power drill to get that rubber out of the rear guards. I primed mine after to cover a few spots were it got down to metal, and then once rolled used some black caulking **** along the top of the fold to prevent water building up in there.
    SILVER '98 MKIII GOLF GL // BORBET TYPE A's
    YELLOW '76 B1 PASSAT LS WAGON
    WHITE '07 MKV JETTA 2.0 TFSI
    FLICKR
  3. #33
    Aug 2006
    Melbourne VIC
    foff has CX and his was one of the lowest static Mk3's in Aus.
  4. #34
    Aug 2009
    ACT
    Increases spring preload for more lows, can even modify the front mount and thread it on upside down to get more lows, there's details on vortex thread somewhere
  5. #35
    Apr 2013
    Central Coast
    Quote Originally Posted by anthony--t View Post
    Bonnet no longer chalkboard?
    Regarding rear guards. Gotta get that sticky stuff out. Use a wire wheel or whatever you can to scrape it out then you can roll guards.
    I got tired of that chalkboard bonnet quicker than i thought haha.
    Will give it a try with the sticky stuff and let you know thanks.
    Screwdriver and heat the rubber goo comes out easy.
    I have recently got cx's and they are far from low coil overs. Don't know what the go is.
    Well i they sat alright untill i stiffened the spring rate, then it just wouldn't get low enough, which sucks.
    Quote Originally Posted by frankeshh View Post
    Love the car man! Where did you buy dem rimsss and how much? they look dank
    Thanks man! I got them from here: Nemoto Borb 15x8 +10 4x100/114.3 otomoto.com.au
    They're only reps though, but good enough for now while i save some $$.
    Quote Originally Posted by LankyVW View Post
    I originally had CX's, but i busted a front one from incorrect istallation haha. So i have CX's in the rear and JOMs in the front.
    I'll give the Vortex thread a look, thanks.
    Alright thanks for the tip on the rubbery stuff, will get at it ASAP!
    '98 Golf Mk3 4 Door
  6. #36
    Jun 2011
    The method foff as said is the way to go. I had one side preloaded 20mm the other not so. The side I preloaded now slams but the side I didn't preload won't. Guess the spring just settled quicker
    "I only post on Facebook if I know i am going to get likes" - M
  7. #37
    Apr 2013
    Central Coast
    So after almost getting defected again on Monday, I decided to raise the front a little again.could probably go a little higher but haven't got the time today.
    I took a heat gun and wire brush to the rear guard, only did the front of the rear left and rolled it a tiny bit till I can have it done properly, but it's just the front half that was chewing it up, also noticed the rear axle isn't centered? Is that hard to fix?
    '98 Golf Mk3 4 Door
  8. #38
    Mar 2011
    Inner West, NSW
    Quote Originally Posted by Blep View Post
    Now there's not something you hear everyday!
  9. #39
    Apr 2013
    Central Coast
    Quote Originally Posted by drucejnr View Post
    I never thought I'd say it either, but unfortunately I can't afford to be defected at this stage haha.
    Does anyone know the legality of the Blue Tinted Hella tails? I'd like a set, just don't know if defectable or not?
    '98 Golf Mk3 4 Door
  10. #40
    Jun 2011
    I've been rolling around with them for a while now not an issue.
    I'm also under the impression as they are 'legit' not tinted there isn't a problem
