I've looked into these and have basically concluded that If you want the look then yeah go ahead... just remember that the coils start at around 50US each and then you need to do the wiring and the bracket and the coils off the coilpack's ECM which may also be quite old.
Amazon and Ebay have the cheapest ones, also keep in mind that the VN-VR commodores can use the same individual coils at the VR6... That also means that you can use a VN ignition coil as a coil-pack replacement for about $80 parts cost.
