Have a hunt on vwvortex. There are some DIY's there. If you have no luck im sure i have one at home. I moved mine to get my bonrath CAI in. Is pretty easy.![]()
On my 94 golf vr6 I want to move my carbon canister to the other side.(From the air box side to the other side to free up some space)
Does any one know any good threads for moving the canister to the other side??
I am trying to avoid the hassle of having to remove the whole bumper bar just to check what the right thickness is for the tubing that connect to the canister, does any one know what are the thickness and how much tubing I have to buy??.
If any one has any advise on this topic or any experiences
Please let me know It will be greatly appreciated
Thanks!!
Just throw it away...i did...
Isn't that the emmissions canister though?Originally Posted by golf3
Try this though it was started a while ago
http://www.vwwatercooled.org.au/newf...ead.php?t=2669
Yeah its one of the first emmissions requirements on cars back in 76 /77 ????
If I was to relocate I wouldnt put it too far away from its original location , it just doesnt look good having 2 fuel line size hoses running from one side of the engine to the other , then there is the " how effective is it running that distance ????
It seems as though most people put it on the other side so you think this could possibly be not so good??Originally Posted by Bug_racer
If u don't wanna move the canister you have other options. I just bumped up a useful thread for you Kenji (the one Steve Mk3vr6 put a link through for) you should check out my pics on the last page...
John
Canadian dubs coming to VWwA soon
I pulled out the air box today to have a look.Originally Posted by Golfer
I would prefert to do it your way golfer but with the vr6
Between the starter and the grill(bumper) is very crammed
I there is a way to do it your way it would save so much damn time and effort!!![]()
Ask Alex (KI11Z)
He has the exact same setup on his VR6 (that's where i got the idea).
The only difference is that he has removed the canister as well and moved it to the other side of his car and put in two pipes (one in the same place as mine and one down through the canister opening...
I think it's a little bit of overkill, but it sounds mad!!!
In terms of pipework you might as well put it in the rear , only thing is you have to run wires for the solenoid . I'll look into it when I get another VR6
