Oh... the and the heatercore is an absolute bitch of a job. Even workshops take a full day most of the time since you have to remove pretty much everything forward of the handbrake to get at it.
3. Appears to be a vacuum line above the heater core hoses, that is not connected.
From memory this is the vacuum line for the cruise control??? I think.
4. Further plastic line under battery near headlight goes to nothing.
Vacuum line for the cruise control (which I'm assuming doesn't work).
9. Airbag light is on and my VCDS won't read the controller! Yet to investigate further.
12. Breather hose to inlet is in 3 pieces.
If you're not too concerned, vento to atmo
13. Stereo is missing. Would a mk4 cd unit plug in?
Any single DIN CD player will fit the issue with an OEM one is the code if it needs one. Assuming you have that, go nuts.
(For my money you might as well buy a head unit with bluetooth and USB.
There is a strange foam box in the boot RHS near tail light. It splits in 2 and has some sort of electrical thing inside. What is this?
That's a vacuum pump to run the central locking. The system fails for one of two reasons, either the pump is dead (which is an easy fix) or one of the lines are cracked/broken/disconnected which can be a nightmare to find. If you can get it working you can splice in a remote central module like I did here (post 13):
Mk3 Switchblade :)
If not an after market remote central locking kit with door actuators can be installed instead.
Seriously remote central locking just makes the car that much nicer day to day and makes it feel much more modern.
Thankyou Mr hawk. You still rocking a multivan?
3. Think I can connect this end.
4. Not sure where it connects to?
12. I'll attempt to get a new one.
13. With the stereo, is the factory plug the same between mk3 and mk4?
Central locking works with a key, I just wanted to know what the box was.
Now where should it sit as mine is on the boot floor in that corner?
Thanks so much for educating me, just makes the process that much easier for me![]()
Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
Originally Posted by JoeVR
I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
Yep still in the Van and the Golf.
4 goes to a reservoir in the quarter panel that hold air pressure.
12 is expensive since you need that while I take hose assembly, not just the little bit.
13. Probably but I guarantee nothing. Remember that you still need that all important Pin.
While it won't be OEM, I'm a huge fan of hands free.
That central locking pump has a foam case that lives behind the carpet lining... Maybe you get lucky and its in there!!
I used to get a lot of parts from here for my mk3 back in the day:
GermanAutoParts.com
3. is for the flaps to work as in the recirc ones
4. sounds like the pump in the passenger wheel well ( if you remove the fender liner you will see the pump )
12. sounds like you are talking about the pcv? be ready for a shock when they ask for $150-$210 for a new unit which is also no longer produced, you may find ones that are sitting in stock and also becareful that the early and later cars use a different intake elbow. Alot of the guys run a catch can or just run a hose from block to intake elbow
13. im pulling the original mk3 system out to replace if you want it it yours free
Polo GTI
T-Roc R
Tiguan R
Tiguan 162 Allspace Wolfsburg
Just put a catch can in and vent it to atmosphere. Easiest solution
ive got a **** tonne of bits and pieces if you are chasing anything mate
