Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: modified cup holder
    Jun 2013
    Leichhardt, NSW
    modified cup holder
    Has anyone by chance modified a us spec cup holder to to fit a rhd? Ive heard that this can be done however im trying to think how as the end up the cup holder is angled to the left of the console, not right light ours..
    Easier to get a us spec lhd console?
    Mar 2013
    Brisbane QLD
    What car?...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jun 2013
    Leichhardt, NSW
    mk3 golf.(VR6) American mk3 3's have cupholders standard but the end angels left, not right. my understandingis that these can be modified to fit?
    Aug 2006
    Melbourne VIC
    Iv noticed teh cup holders in US spec Mk3's to be in a pretty poor spot. Like most people put stuff in the centre console. Iv seen some of those cheap autobahn slim line dash vent holders that would work well on a Mk3.
    Check out rays setup in the sticky section.
    I have some US ones too, bit of a odd fit in the us cars too
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2013
    Leichhardt, NSW
    ive seen some others that fold and sit on he side of the centre console. may be an option. From what ive read, jap spec Mk3s also have cup holders and these of course would be rhd... the search continues...
    Mar 2012
    Central Coast, NSW
    modified cup holder
    I had started working on one yesterday. Hacked up one with a dremel, used a soldering iron to plastic weld it in place and then sikaflex to close up any gaps. Turned out average. Still need to clean up some of the sikaflex residue
    Jun 2013
    Leichhardt, NSW
    I take it that its the right front / side that needs to be cut. One of those things where hopefully some time and patience will give us both a good end result. Did it fit without cutting back the front right?My ununderstanding is they fit but don't lock in place?
    Mar 2012
    Central Coast, NSW
    modified cup holder
    I cut out the whole bottom of the console so it sits down inside it. Was a lot of trial and error, test fitting and mucking around. I got a little over it and cut a little too much so it definitely isn't perfect. After the hole was cut I melted the plastic together from the bottom so hopefully it won't move.
