Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: MKIII golf, some electrical gremlins and a lousy sounding clutch :(
    Apr 2011
    so when i go to put the wipers on.....they dont come on, but if i pull the stalk to wash / wipe the windscreen, the wipers do that, just not wipe continuously by themselves. very frustrating any ideas guys?
    also, my clutch pedal is rather limp and without any resistance in it when i press it in for the first half of its journey to the floor (if that makes sense) it kind of feels like there is limited fluid but i cant see anywhere in the engine bay to top the fluid up....and once the clutch is in, the clutch sounds like if you had two sheets of glass and were rubbing them together you also had sand in between those two sheets (im trying to describe it the best lol) and this noise is rather disconcerting. the gear changes are reasonable good, except for trying ot get into first and reverse sometimes is a bit of a task.....i suspect worn syncros?
    and in closing, seeing as i have only ever owned r31's before my golf, is there anything else i should be aware of in terms of build faults / common flaws etc etc? thanks fellas
    hicko
    Apr 2011
    Hmm, had my VR6 for a week now so no expert, but my electrical faults are:
    - ABS light constantly on
    - Park brake light constantly on
    - passenger window works intermittently
    - cruise control not working
    Not sure if these are all common faults or not.....
    Apr 2011
    my cruise control also doesnt work
    Jun 2008
    Hobart, TAS
    Wiper stalk sounds like the relay has gone, try a fresh one
    Not sure which one it is off the top of my head tho sorry
    Jan 2010
    I Had similar problems... which some i fixed, some of my solutions below (might not be 100% correct)
    ABS - check connections behind fuse panel, red and yellow junction, otherwise you'll need a VAGCOM to plug in to check the error.
    Park Brake - thats easy, take of centre console and check the pressure switch
    Window - check connections in door, if it continues, the motor or reg might be on the way out so leave some gaffer tape in ya car, if it fails tape it up.
    Cruise control - usually a vacuum hose leak, not always easy to find, i bought some kiddies chalk from the supermarket crushed it up and put over all the lines, found a few leaks, fixed em up...
    Apr 2011
    Awesome, thank you.
    Apr 2011
    way to hijack my thread lol.
    anyways, one thing i thought of today that i didnt ask the other day was, are the clutches in these things hydraulic or cable? and if they are cable, where am i able to adjust the cable? if hydraulic, where about do i check clutch fluid levels as i be buggered if i could see it in the engine bay.
    also, any ideas on a cost for a set of extractors and zorst? new and 2nd hand?
    thanks guys for the help so far
    Apr 2011
    Sorry mate, didnt mean to do that, was just listing my elec faults in case they were common
    Camden, Sydney
    Hicko. Is your car a 2L? 1.8L? Or VR6??
    All except VR6 have a cable clutch with a self adjusting cable.
    If clutch is slipping revs will move faster than the speedo needle in third when you boot it.
    Noises from the box are likely to be the gearbox itself.
    Wiper stalk is probably the culprit, or relay.
    Cruise control rarely works on a mk3.
    Apr 2011
    2l so, its a cable clutch. is it adjustable? i wish i had a VR6 lol. but thats besides the point.
    are the gearboxes sealed units or are they able to be serviced? eg, fluid change?
    the clutch doesnt seem to be slipping it, the pedal jsut has no feel until its halfway to the floor....id rather have the clutch engaging sooner if possible.
