Results 31 to 37 of 37
Thread: The MkIII DIY Thread
  1. #31
    I just did mine in the mk3 and I needed a single flat each side. Might depend what unit you have
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #32
    May 2013
    Orange NSW
    Making two U shaped tools did the trick. Then I found the new aerial was a standard plug on the end not the Euro plug. A quick trip to Supercheap but they could only order it for $21. I walked to Autobarn nearby and they had the correct adaptor for $10 with the same part number and manufacturer that Supercheap was going to get.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
  3. #33
    LAUNCESTON, TAS
    Wiring diagram for wiring HID angel eyes i just did.
    this will have your HALOS running when the car is running (AUX)
    just thought it would come in handy for anyone.
    Attached Thumbnails Attached Thumbnails The MkIII DIY Thread-untitled-jpg
  4. #34
    Dec 2014
    Quote Originally Posted by thestu View Post
    VWVortex.com - window regulator diy
    HANDY!!!!! window reg fix!
    Thanks I found this really useful in helping me fit a repair kit that I bought from ebay. The moderator should put it with the other guides in the first post
  5. #35
    Mar 2014
    Bundoora, Victoria
    My cable tie in my reg assembly broke last night after work. So at 12:30AM in the heat I was fixing this by just bolting it shut after taking the reg out, not something I wanted to do after a 9 hour shift in the heat.
    Looks like the cable tie could keep up with the strain for a few months after becoming weak and breaking. I wonder if it's possible for a more permanent fix, or is it just bad luck?
    Past - '95 VW Golf MK3 VR6
  6. #36
    Sep 2016
    Hello!
    Does anyone know where to get replacement side mirror caps?
    (the plastic front face)
    Would be super appreciative.
    Thanks,
  7. #37
    Nov 2015
    Ebay is your friend although in this case international postage is not:
    VW Golf MK3 92-98 Vento 92-98 - OE Quality Right Side Wing Mirror Cover Black
    If you are in Sydney, you could try Camden GTI who seem to have a fair few Golf 3 parts in stock or some of the wreckers around the traps such as Pick n Payless.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
